1997 Mitsubishi Eclipse car purges coolant
245,000 MILES • 4 CYL • FWD • MANUAL
HUKTONFONIX
2 months ago, I was driving 30 mph and my thermostat started going up. I turned off the engine, looked behind me and saw a trail of coolant going down the street. After adding water and antifreeze, the car was fine. No leaks or anything. Last night, the same thing happened. I was driving around 70 mph and saw my thermostat going up. When I looked under the car, I saw coolant dripping underneath my engine. Once again, I added water and coolant and drove the car home. It looks fine now (no leaks or anything). Why is my car purging its coolant? Do I have to replace the thermostat?
Sep 13, 2008 at 2:11 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
I feel that it is time to do a cooling system service, first have the system pressure tested for and minor external leaks, also check the pressure cap, change the thermostat and get the radiator cleaned & flow tested, finally make sure that the cooling fans are working correctly. start here.
mark (mhpautos)
Sep 13, 2008 at 3:28 PM
