1997 Mitsubishi Eclipse Car bogging out
UNIVAMP20032000
Engine Mechanical problem
1997 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic
Hello! I was wondering why my car is bogging out when I step in the gas? We have replaced the spark plugs, the fuel filter and one of the fuel injectors. It idles fine but when I step on the gas to go, it bogs out. Was wondering if it is dirty fuel injectors or something else? Thank you.
May 20, 2010 at 6:22 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 20, 2010 at 8:59 AM
