1997 Mitsubishi Eclipse battery replaced and still no power
1997 MITSUBISHI ECLIPSE
130,000 MILES • 4 CYL • FWD • MANUAL
PEMILLER22
I replaed the battery, and still have no power. Nothing what so ever. Where can I access a manual to verify it is installed correctly? I never had an unser manual. I don't believe I have a dirty connection since I cleaned all connections. Any other suggestions on what the problem might be? I can't see paying 100s of dollars to hear that I had the washer/cables connected in the wrong order on the battery. Poasts are on the top of the battery.
Nov 24, 2008 at 12:33 AM
ZACKMAN
  • 4,202 POSTS
Red cable to positive terminal and black cable to negative terminal, right?
Open the fuse/relay box under the hood. Make sure all fusible link are still good. Usually the main link (80A sometimes 100A) is broken.
Nov 25, 2008 at 5:00 PM
