1997 Mitsubishi Eclipse 97 Eclipse stalled and will not sta
WMB007
  • 5 POSTS
Computer problem
1997 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual
Hi, my eclipse 97 2.0 man/tran would die on me when I would slow down sometimes but this last time it sputtered and died. I lost fuel pump and injectors when the key is turned on total silence. it cranks fine but fuel pump does not run. My book said to run a hot to the pump to check it an it runs I also checked the fuel pump relay it is not getting power. so I assume the ASD relay is not getting power also, does it sound like my PCM failed. I have checked all fuses all good.
thanks......
Aug 20, 2009 at 5:15 PM
  • 75,988 POSTS
Check the coil and injector harnes black and red wire do you have power also check the fusible link no.4 30amp-let me know
Aug 20, 2009 at 9:02 PM
WMB007
  • 5 POSTS
hi.thanks for the quick responce,
I pulled both harness connectors coil,injectors and checked B/R for volts with key on : no power to ground, did I check it correctly also fuse is good.
thanks
Aug 21, 2009 at 3:45 AM
  • 75,988 POSTS
Check and test the ASD relay or swap it and see what happens
Aug 21, 2009 at 5:25 AM
WMB007
  • 5 POSTS
I swapped both no change I jumped power to both relays and they close fine.
Aug 21, 2009 at 6:40 AM
  • 75,988 POSTS
Did you check the fusible link no.4 30amp in the engine compartment relay box. Do so
Turn key on and check for power on pin6 black and white wire on fuel pump relay socket-let me know for both
Aug 21, 2009 at 6:57 AM
WMB007
  • 5 POSTS
no power at scocket r/w pump relay
I have to leave for work soon
thanks for the help
Aug 21, 2009 at 7:22 AM
  • 75,988 POSTS
Check the black and white wire on the fuel pump relay socket this powers the coil side of the relay
Aug 21, 2009 at 7:28 AM
WMB007
  • 5 POSTS
on way to work will have to check back later thanks
Aug 21, 2009 at 7:40 AM
