1997 Mitsubishi Eclipse
150,000 MILES • 4 CYL • 2WD • MANUAL
CHRISTINAO8806
I am having trouble with 2 main things on my car. The first is my backup lights. They have not worked for some time now. I have checked the bulbs and the fuses neither is the case. I'm thinking it is the backup light switch which I need to know where to locate that and how to replace it. Second my horn is not working aside from the fuse which is fine i'm not sure where to look to check on that. I believe it may not be plugged in because when I had my motor replaced it has not worked since then. I would need to know how to check that.
Dec 21, 2007 at 7:25 AM
LUGNUTTERMAN
  • 5 POSTS
replaced the bulbs first what do you mean you checked them
Dec 21, 2007 at 7:52 AM
CHRISTINAO8806
i replaced the bulbs first and checked the socket to make sure it was not in the wiring.
Dec 21, 2007 at 1:37 PM
