I put a new alternator on the car, had the front end jacked up. Started the car after the alternator installed to see if alternator light went out. The alternator working find and took car off jacks 24 hours later car will not crank. It will turn over but will not start. Put new fuel filter on car, fuel pump runs (audio), used OBD II on car no codes come back. car will not start all relays appear good, ignition coil has good resistance.
Dec 24, 2009 at 11:22 AM
