1996 Mitsubishi Eclipse Will Not crank
SPRAD46
  • 1996 MITSUBISHI ECLIPSE
  • 4 CYL
  • FWD
  • 150,000 MILES
I put a new alternator on the car, had the front end jacked up. Started the car after the alternator installed to see if alternator light went out. The alternator working find and took car off jacks 24 hours later car will not crank. It will turn over but will not start. Put new fuel filter on car, fuel pump runs (audio), used OBD II on car no codes come back. Car will not start all relays appear good, ignition coil has good resistance.
Thursday, December 24th, 2009 AT 7:22 PM
  • 109,885 POSTS
Are you getting spark and fuel to the engine. Did you check fuel pressure?
Thursday, December 24th, 2009 AT 8:09 PM
SPRAD46
Yes I know getting fuel do not know how much pressure
Thursday, December 24th, 2009 AT 8:20 PM
  • 109,885 POSTS
I recommend checking fuel pump pressure. You may have fuel but if the pressure is too low, it will cause problems. Here is a how to for checking:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a fuel pressre gauge. Most parts stores will lend or rent them.
Let me know what you find.
Sunday, December 27th, 2009 AT 12:38 AM
