1996 Mitsubishi Eclipse Trouble starting my Eclipse.
85,000 MILES • 4 CYL • 2WD • MANUAL
ROBERTSSIX
Sometimes it starts, sometimes not. When the check engine light came on I replaced everything that the codes gave me: O2 sensor, plugs, ignition coil. Less than a week later - not starting again. Light is back on and read Ignition coil again! Also, engine runs rough when it does run. What would you do next?
Jun 18, 2008 at 7:55 AM
KHLOW2008
  • 41,812 POSTS
Hi robertssix,
I would test the coil resistance and check its wiring circuit and connections.
Jun 21, 2008 at 10:24 PM
