1996 Mitsubishi Eclipse question
1996 MITSUBISHI ECLIPSE
66,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHN_JOHN_17
hey guys i have a quick question.. i have a 96 eclipse gst w/auto trans.. my head gasket was cracked so i took it to the shop to repair it..my car used to run so smooth before i took it there.. i had the head gasket replace the intake manifold gasket and the other small gaskets.. i have had the car back now for 5 days and the car is shaking a lot more than it used to (it used to shake a little because i have prothane motor mounts) and it feels like the car is running a lot harder than it used to and also when i accelerate now the car feels like its not getting any juice and it kind of hesitates a little can you please tell me what you think the problem is.. thanks guys
Apr 4, 2008 at 10:23 AM
MASTERTECHTIM
  • 4,750 POSTS
the first thing that comes to mind is the timing belt is off a tooth, messing up the cam timing. have them recheck it.
Apr 4, 2008 at 10:25 AM
JOHN_JOHN_17
thanks guys you were right about the timing belt being off of a tooth.. I just have 1 more question and im not sure if you would know the answer but...I am upgrading the turbo in my car to a t3/t4 turbo will i be able to tune my stock ecu for the new turbo or am i going to have to buy like a greddy emanage or upgrade unit..thanks guys
Apr 20, 2008 at 4:20 AM
