Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Eclipse
Interior
Instrument Cluster
Not Working
1996 Mitsubishi Eclipse gauges wont work
1996 MITSUBISHI ECLIPSE
295,000 MILES • 4 CYL • FWD • MANUAL
CAP4GVN
MEMBER
1 POST
the gauges in my car only work if i kick the fuse block. how can i fix them?
Oct 14, 2010 at 8:18 AM
BLUELIGHTNIN6
Experienced Mechanic
if kicking fuse box turns gauges on then either the fuse is loose in the box or wiring is loose or damaged at the fuse box.
Oct 14, 2010 at 8:47 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
