1996 Mitsubishi Eclipse Engine cranks no start
130,000 MILES • 4 CYL • FWD • MANUAL
MARDY
just bought this spider has 2.0 litre turbo Engine tries to start runs about 10 seconds. It had a blown head gasket(replaced) positive timing is right. It has a lot of
aftermarket parts and some parts from wreckers
got spark got fuel check engine light does not come on with ignition tried taking exhaust off in case cat was plugged does check eng or alt warning light power the pcm ? can.t check any obd codes if lights don,t flash
Don't know were to look next
May 18, 2010 at 1:20 PM
  • 75,988 POSTS
Fuse no.11 10amp powers the PCM its in the engine compartment relay box
May 18, 2010 at 5:54 PM
