1996 Mitsubishi Eclipse Eclipse doesn't crank + unplugged w
130,000 MILES • 4 CYL • 4WD • MANUAL
JPPHD
I can't crank my 96' mitsubishi eclipse. I found Indeed an unplugged white connector just below the dashboard at the driver's side. The problem is, I already looked many times but I can't find where I should plug this connector, any hints? Should I remove some parts of the steering column in order to found the correct place to attach the connector? It's white, rectangular shape, has 12 pins but only 9 wires...(See picture, please)
Thanks a lot,
Joao Paulo
[img:9255f2fb19]http://www.2carpros.com/forum/automotive_pictures/258068_IMG_1646_1.jpg[/img:9255f2fb19]
Update: I just removed the plastic covers of the steering column, but I still don't see any place to plug that wire... everything seems to be plugged inside the column... other suggestions?
Thanks!
Oct 18, 2008 at 12:42 PM
JNOVACK
  • 723 POSTS
I would start there it looks like a plug for the ignition
Oct 18, 2008 at 2:55 PM
