1996 Mitsubishi Eclipse Clutch
148,000 MILES • 4 CYL • 2WD • MANUAL
ITSXJUSTXMANDY
Hi. When I step on the clutch, it feels like it's not catching, then when I try to shift gear, it won't let me shift into a gear. What could be the problem?
Jun 14, 2008 at 6:32 AM
DOCFIXIT
  • 18,828 POSTS
Have you checked the fluid level in clutch master cylinder? Also the slave cylinder on the transaxle may be leaking . And the clutch may worn out when was it last replaced ?
Let me know
Jun 14, 2008 at 6:50 AM
