1996 Mitsubishi Eclipse cat
1996 MITSUBISHI ECLIPSE
155,000 MILES • 4 CYL • 2WD • AUTOMATIC
OCONNER99
my cat is not makeing me go fast i speed up to bout 3 or 4 thousand rpms an i am not going anywhere is my cat going out
Feb 9, 2010 at 10:56 PM
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Feb 9, 2010 at 10:58 PM
