1996 Mitsubishi Eclipse blinkers
1996 MITSUBISHI ECLIPSE
GRAYSGARAGE
Electrical problem
1996 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic
BLINKERS DON'T WORK. THE EMERGENCY FLASHERS WORK, ALL BULBS AND FUSES ARE GOOD, THE HEADLIGHTS WORK, ALL TAILIGHTS WORK. COULD THE PROBLEM LIE IN THE STEERING COLUMN, PARTICULARILY WITH THE BLINKER SWITCH? IS THERE ANY SPECIFIC BLINKER FUSE BOX SOMEWHERE OTHER THAN THE FUSE PANEL IN OR OUT OF THE CAR?
Mar 22, 2009 at 3:30 PM
GREENJC
  • 7 POSTS
I would agree with you that column multifunction switch is probably the problem since you have checked the fuses and bulbs. Unfortuneatly these switches tend to be pretty expensive.
Mar 28, 2009 at 1:47 PM
