1995 Mitsubishi Eclipse vehicle does not start
98,000 MILES • 4 CYL • FWD • AUTOMATIC
FRANK4824
Gentlemen, the vehicle i have has a chrysler engine The vehicle does not start. I have no current at the ignition. I checked the timing,crankshaft sensor,camshaft sensor. The check engine light turns on and off. I changed the ecu. and i still cant get any current at the ignition. ive also checked according to the chilton manuel the volts and ohms for each part i mentioned before. ive also checked the cables and still no response. vehicle is a mitsubishi Eclipse 1995 2.0 non turbo twin cam engine please help
Apr 25, 2010 at 8:59 AM
  • 75,988 POSTS
I have no current at the ignition. Are you refering this to noj power to coil or no spark
No spark could be the coil,power transistor and computer itself
Apr 26, 2010 at 8:17 PM
