1995 Mitsubishi Eclipse RE: 95 Eclipse Sputter
205,000 MILES • 4 CYL • FWD • MANUAL
JMICHAEL2010
  • 8 POSTS
I had a post before this, but my eclipse is having problems like other peoples on here. When im in a low rpm and not trying to give it alot of gas it does fine but when i try to accelerate fast it missfires severely. I hooked it up to one of those hand held computers and it said cyl 1 malfunction, is that a misfire? and another thing is that my idle for my car is about 1400 rpm's, what could cause this? i cleaned my egr valve and fixed some of my vacume hoses but nothing seemed to help. And for the cyl 1 malfuction, i checked wires, looked fine, checked plugs, looks fine, replaced the cyl 1 plug, didn't hlep any. and i tested the coil and they all had spark. Could it be not getting enough spark or what? what are some things i can look at on my car for these problems? Thank you for your help!
Nov 2, 2009 at 2:22 AM
JMICHAEL2010
  • 8 POSTS
Could it be the throttle position sensor? it has symptoms like a totall power loss when the throttle is fully engaged because it sputters, and when i punch the throttle it makes like a poping noise somewhere under the hood.. Its kinda like a persons first time driving a standard. and when it idles the rpms is about 1400 when it should be like 800. When i come up to a stop sign and stop, sometimes the rpms will get hesitate for a second and i have to wait for it to go back down. Plz help!
Nov 5, 2009 at 12:22 PM
