1995 Mitsubishi Eclipse no dash lights
1995 MITSUBISHI ECLIPSE
15,000 MILES • 4 CYL • FWD • MANUAL
IBILLYMAC91
  • 6 POSTS
i was trying to install an new radio deck in my car and after was all said and done i dont know exactly what i did but there are nore dash lights and i cant figure it out how to fix it! do you have any suggestions or ways to fix it? thank you
Feb 23, 2009 at 11:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
First you should inspect your fuses. Let me know how they are and I will follow up.
Thanks for using 2CarPros.com!
Feb 23, 2009 at 11:18 AM
IBILLYMAC91
  • 6 POSTS
fuses are all good have checked them over a couple times, i was wondering if it was one of those relays, but i still odnt know
Feb 23, 2009 at 12:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Wouldn't be a relay. How about a dimmer switch, did you accidentally knock it? I have done it before... Other lights working ? Interior, headlights?
Feb 23, 2009 at 2:36 PM
IBILLYMAC91
  • 6 POSTS
i hav looked and the dimmer switch and everything was connected! and my headlights work and lights work when i open my doors it just the instrument pannel and stuff!
Feb 24, 2009 at 12:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
A/C controls light up? If its just your gauges then there is either a wire that is loose, a fuse blown, or the gauge cluster needs replaced.
Feb 24, 2009 at 2:35 PM
IBILLYMAC91
  • 6 POSTS
oh no the ac controls dont light up!
Feb 25, 2009 at 5:44 AM
