1995 Mitsubishi Eclipse jerking on aceleration
169,000 MILES • 4 CYL • FWD • MANUAL
CRAZE_WILLSON
my car jerks on aceleration, i have changed plugs, wires, had entire electrical checked, wit no problems, first gear is fine, but after shiftin to any other gear, when i try to acel it jerks shutters, repeadly, as long as i only touch my gas just enough to get the RPMS to move it is fine with little jumps, but under normal acel it jerks so bad i lose speed, i have no ideal what it is or could be, have changed oil, i have no leaks, an everytime it starts jerking the check engine light pops on but after i cut the car off an strat it back bout 99% of the time the light cuts off once in a while it stays on but always cut off after that
Jul 30, 2010 at 7:52 AM
  • 75,988 POSTS
Check engine light:
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Jul 30, 2010 at 3:16 PM
