my car jerks on aceleration, i have changed plugs, wires, had entire electrical checked, wit no problems, first gear is fine, but after shiftin to any other gear, when i try to acel it jerks shutters, repeadly, as long as i only touch my gas just enough to get the RPMS to move it is fine with little jumps, but under normal acel it jerks so bad i lose speed, i have no ideal what it is or could be, have changed oil, i have no leaks, an everytime it starts jerking the check engine light pops on but after i cut the car off an strat it back bout 99% of the time the light cuts off once in a while it stays on but always cut off after that
Jul 30, 2010 at 7:52 AM
