1995 Mitsubishi Eclipse Ho to remove cv joint
1995 MITSUBISHI ECLIPSE
170,000 MILES • 4 CYL • 2WD • MANUAL
JEFFRYGO
The inner cv boot on left side or driverside worn out and the cv boot completly seperate, we already remove the hub we also remove the knuckle cuz we gna change the control arm bushings but how can i remove the cv joint out from the car or engine to replace the boot and grease. Thank you.
Aug 23, 2010 at 11:06 AM
WRENCHTECH
  • 20,761 POSTS
We don't really take those apart any more. you can buy an entire remanufactured axle for $50 to $60 and it's a lot less labor.
Aug 23, 2010 at 11:12 AM
