1995 Mitsubishi Eclipse Change motor
WILLYD
Engine Mechanical problem
1995 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic
Hows the best way to change this motor and what to look for while motor is out
Apr 14, 2009 at 11:12 PM
GRAYSGARAGE
If you are replacing your motor, there is nothing really to "look for" while the motor is out of the car. If the motor is the problem, all will be good when it is replaced. I would recommend replacing the timing belt and water pump.
[quote:4d224035b8="willyd"]Engine Mechanical problem
Hows the best way to change this motor and what to look for while motor is out[/quote:4d224035b8]
Apr 15, 2009 at 9:16 AM
