1995 Mitsubishi Eclipse CAR NOT STARTING
185,000 MILES • 4 CYL • FWD • MANUAL
BLONDDEE
IT WAS. SPARK NOCKING I CHANGED THE PCV VALE AND SPARK PLUGS THE MOTOR IS TURNING OVER SLOWLY IT IS GETTING FIRE TO THE PLUGS . AND GETTING FUEL BUT WONT START
Feb 3, 2009 at 9:21 AM
  • 75,988 POSTS
Check the fuel pressure make sure the fuel pump is producing the correct fuel pressure and also check if your injector/s are pulsing
Feb 3, 2009 at 9:38 AM
