HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Eclipse
Electrical
Battery
Replace/Remove
1995 Mitsubishi Eclipse Battery
KJOLIVEIRA
MEMBER
1995 MITSUBISHI ECLIPSE
6 CYL
2WD
AUTOMATIC
122,000 MILES
What type of battery do I use to replace the old one?
Thursday, September 9th, 2010 AT 2:12 PM
MECHANIC
See chart below
Cold cranking amps: 525cca
Group no. 86
P/N A995FB1X01
Thursday, September 9th, 2010 AT 2:32 PM
Please
login
or
register
to post a reply.
Related Battery Replace/Remove Content
1997 Mitsubishi Eclipse Battery Replaced And Still No...
I Replaed The Battery, And Still Have No Power. Nothing What So Ever. Where Can I Access A Manual To Verify It Is Installed Correctly? I...
Asked by
pemiller22
1 ANSWER
1997
MITSUBISHI ECLIPSE
VIDEO
Battery Replacement
Instructional repair video
GUIDE
Battery Replacement
Replacing a car battery is easy to do and will take about 20 minutes in most cases, this job can be done using everyday tools. Please wear protective gloves and eyewear when...
Drains Quick
My 96 Eclipse Drains The Battery After It Starts Up Bout 15-20 Min. Ive Changed The Battery N Starter N Alternator. Any Suggestions. The...
Asked by
jrod210.15
1996
MITSUBISHI ECLIPSE
2000 Mitsubishi Eclipse Battery Keeps Dying
Hi, Have A 2000 Mitsu Eclipse That I Purchased Back In August. Aside From Normal Wear And Tear The Car Seems To Be In Excellent Shape...
Asked by
KaonSZ
1 ANSWER
2000
MITSUBISHI ECLIPSE
Parasitic Battery Drain
Hi: I Recently Had My Battery Replaced And It Died Three Months Later. I Was Told That This Could Be The Result Of A Battery Drain Because...
Asked by
fuse*1945
2001
MITSUBISHI ECLIPSE
2003 Mitsubishi Eclipse Jump Started Car Backwards
Ok, Well My Battery Died One Day. We Got A New Alternator On It And A New Battery. Before I Did That Though I Tried To Jumpstart It And The...
Asked by
dietrich24
2003
MITSUBISHI ECLIPSE
VIEW MORE
Battery Replacement Dodge
Battery Replacement Ford
