1994 Mitsubishi Eclipse Wont Start
149,200 MILES • 4 CYL • FWD • MANUAL
MCCUERF
I have been trying to figure it out myself but at no success. When I was driving home from work my radiator hose popped off, then my check engine light came on, by the time I could get off on a side road my car stooped running. I filled it back up with fluid and tried to crank it over but it would not fire up, so I towed it to my house, I then ripped it apart to check the timing belt and it was still intac, then I checked to make sure that it was getting spark to all cyclinders and it is, then i checked to make sure it was getting fuel and it is, I also checked all the fuses on the entire car and they are all good, so now I am at a lost again. can someone please help me out with my problem?
Thank you Randy
Jul 6, 2008 at 6:44 AM
BMRFIXIT
  • 19,053 POSTS
Pull spark plugs and check for a compression
possible headgasket and or head issue
Jul 6, 2008 at 6:50 AM
