1994 Mitsubishi Eclipse will not start and run
180,000 MILES • 4 CYL • FWD • MANUAL
ROBINS976
i have a 1994 eclipse gs 1.8l engine i replaced the distrebutor timeing belt fuel pump all relays ecm plugs and wires i try to start it might start for 1 to 2 sec then shut off do you know what it is i cant thanks
Aug 18, 2010 at 11:03 AM
  • 75,988 POSTS
Check the fuel pressure if okay check and test the idle speed motor sensor, aiflow sensor, throttle sensor and ignition switch
Aug 18, 2010 at 11:13 AM
