1994 Mitsubishi Eclipse overheats
183,000 MILES • 4 CYL • FWD • MANUAL
MTHOM
my 94 eclipse temp gauge goes to half way mark within 5 minutes of starting,and will go to 3/4 way if i do 70 mph or faster, or if in stop and go traffic it will run hot, i replaced temp sending unit, checked water pump , replaced thermostat, radiator is not clogged and fans are working . what else im i missing ?
thanks for your time!!!!!!
Jun 19, 2008 at 12:06 AM
KHLOW2008
  • 41,812 POSTS
Hi mthom,
Coolant is not flowing fast enough in the system.
1. Weak water pump.
2. Clogged water passage including radiator.
Jun 21, 2008 at 10:27 PM
