1994 Mitsubishi Eclipse Overheating
BRYANR2010
Engine Cooling problem
1994 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual
It continues to overheat and i have to keep adding water to the radiator. and it used to smoke white smoke do you know what could be wrong?
Oct 10, 2010 at 12:12 PM
  • 75,988 POSTS
Try replacing the thermostat-don't work get it block and pressure tested-
Oct 10, 2010 at 12:14 PM
BRYANR2010
[quote:8625e28276="rasmataz"]Try replacing the thermostat-don't work get it block and pressure tested-[/quote:8625e28276] I have already replaced the thermostat, how would i get it pressure tested?
Oct 10, 2010 at 2:18 PM
NEFI154
  • 9 POSTS
take it to any mechanic and ask them to do a compression test. aslo you could have burned your head gasket not likely thoe, or your water pump may need to be replaced. try flushing the raditator first.
Oct 20, 2010 at 4:30 AM
