1994 Mitsubishi Eclipse mysterious light on dash?
1994 MITSUBISHI ECLIPSE
JALEXANDER52
Electrical problem
1994 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual 126xxx miles
Hello i have there's a light on my dash that is right next to the check engine light that stays on. I have no clue what it is but my car seems to be running pretty good. I'm not sure if its an oil change light or what. can you help me out
Aug 2, 2010 at 11:05 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
is the light in a carousel shape and beside the open door ajar light? if so it means oxygen sensors need replaced.
Aug 2, 2010 at 11:31 PM
JALEXANDER52
Yes it looks like a carousel but it passed emissions with flying colors. I'm guessing that could be causing my idling rpm's to range up and down a bit. between 800 and 1300? What's the name of that light?
Aug 2, 2010 at 11:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
don't know if it has a specific name, i just call it the o2 light..
Aug 3, 2010 at 12:14 AM
NEFI154
  • 9 POSTS
your car needs water. add water to it if you havnt checked that already.
Oct 20, 2010 at 11:35 AM
