Can you hear the fuel pump prime up when you first turn the ignition key to ON, without cranking? If not then it is not wired up properly. If the fuel pump is working then the fuel system may need primed, turn key on, no crank, back off several times then try cranking engine.
SPONSORED LINKS
Wednesday, June 30th, 2010 AT 5:07 PM
