1994 Mitsubishi Eclipse dashboard lights
153,000 MILES • 4 CYL • FWD • AUTOMATIC
MIDNITEBLU11
My battery, engine and brake light all lit up on the dashboard last night. The brake was off, and the car started with no problem. Why are all the lights on?
Apr 8, 2009 at 10:44 PM
BMRFIXIT
  • 19,053 POSTS
check fuses
check charging system and suspect bad alternator
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Apr 8, 2009 at 11:19 PM
MIDNITEBLU11
you were right on the money..took it to Advanced Auto Parts and its the alternator..but its my fourth rebuilt..something must be wrong that it keeps going bad
Apr 9, 2009 at 4:43 AM
BMRFIXIT
  • 19,053 POSTS
check the battery and make sure it is big enough for what you have
and the alternator isn’t working over time to keep the battery up
try a different brand
Apr 9, 2009 at 1:41 PM
