1993 Mitsubishi Eclipse wont run in drive or reverse
113,000 MILES • 4 CYL • FWD • AUTOMATIC
ALROY
my car wont run in drive or reverse and it dies in park when you turn on air con. i have to hold the gas pedal to floor to get it to start. whats my problem could it be catalytic converter?
Aug 23, 2009 at 1:13 PM
  • 31,937 POSTS
Hi there, this will more than likely be a problem with the engine manage met system, and the idle control system start with getting a scan done to check for any set fault codes.
mark (mhpautos)
Aug 23, 2009 at 6:16 PM
