1993 Mitsubishi Eclipse radiator
DUSTBALL8449
Engine Cooling problem
1993 Mitsubishi Eclipse 4 cyl Front Wheel Drive 104,00 miles
No frills car dumped the coolant, then the gauge shot up to hot at idle. I never had any problems with it before. Is this a probable thermostat? Before I change the radiator?
Apr 27, 2008 at 6:07 PM
  • 31,937 POSTS
Hi there,
It is worth replacing the thermostat as well as getting the radiator cleaned & pressure tested, hopefully there is no other damage.
mark (mhpautos)
Apr 27, 2008 at 8:38 PM
