1993 Mitsubishi Eclipse
SHELLYMSELL
  • 1993 MITSUBISHI ECLIPSE
Drive Train Axles Bearings problem
1993 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual
I think my clutch is slipping, how can I tell for sure?
Sunday, January 25th, 2009 AT 9:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You can feel the gears disengage if clutch slips. Get to 3000 RPMs in 2nd or 3rd gear and then step on the gas hard (safely!). If the revs go up quickly and yet the car doesn't pull hard, the clutch is slipping.
Thanks for using 2CarPros. Com!
Sunday, January 25th, 2009 AT 9:53 PM
