1993 Mitsubishi Eclipse
93ECLIPSE
Engine problem
1993 Mitsubishi Eclipse 4 cyl Front Wheel Drive 231ooo miles
the car overheats, the thermostate is ok and not sure if the fan works
Jan 6, 2008 at 8:44 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9f4ce69193="93eclipse"]Engine problem
the car overheats, the thermostate is ok and not sure if the fan works[/quote:9f4ce69193]
well you need to check if fans work
also check water pump and radiator
have head gasket tested
Jan 6, 2008 at 9:01 AM
