1992 Mitsubishi Eclipse vehicle will not start
IRLDESIGN
Electrical problem
1992 Mitsubishi Eclipse 4 cyl Two Wheel Drive 175,00 miles
1992 Mitsubshi Eclipse, seemed hard to start last month. I advanced the distributor and the car started and ran better. However, for the past two days it will not start. I have checked everything.
I have tried to check the timing by a crank. I used the 1/2 inch extension and bar , turning the extension bar clockwise until the timing dot was at the tdc mark. Then I positioned the distributor with the rotor button pointing down. If this is not correct please let me know.
I hear a clicking sound and the car is not turning over. I replaced the starter, yet I hear a click, and the battery seems fine, as it checked good /fine the other day.
Please Help ASAP!
Rebecca
Apr 24, 2009 at 9:16 AM
MONTY STEPHENS
  • 79 POSTS
So good battery, new starter -- check your starter relay.
May 4, 2009 at 4:07 AM
