1991 Mitsubishi Eclipse safe mode
87,000 MILES • 4 CYL • FWD • AUTOMATIC
MABRAMSON
i recently replaced the ecm and now my transmission is locked in the "safe mode." how do i remedy this? No problems with the trans prior to ecm replacement.
Apr 6, 2010 at 4:24 AM
KHLOW2008
  • 41,812 POSTS
Hi mabramson,
Thank you for the donation.
First would be to get the trouble codes. For the trans to enter limp mode, some sensor or their wiring could be faulty.
Is the ECM replaced of the correect typew? Did you check the ECM part no?
Apr 7, 2010 at 7:42 AM
MABRAMSON
I have checked the ECM. It is the correct one for the car and when checked for error codes, it reads functioning normally. Transmission is still in failsafe mode. How do I reset the trans so it will shift?
May 22, 2010 at 6:10 AM
KHLOW2008
  • 41,812 POSTS
Disconnect the battery terminals.
Hold the 2 terminals together for a few seconds and reconect.
Restest to see if the problem is resolved.
If you had disconnected any wire couplers, recheck them for proper seating and looseness.
Recheck the ECM and TCM wire harness.
May 22, 2010 at 11:05 AM
