1991 Mitsubishi Eclipse Engine wont turn over "timing&
159,000 MILES • 4 CYL • 2WD • MANUAL
TAKEDOWN
I recently replaced the headgasket on my 1.8 sohc eclipse and now it wont start. Im thinking it has to to with the engine timing because i did tinker with the cams while the head was out. Any ideas on how I could fix this?
May 27, 2009 at 12:47 PM
  • 75,988 POSTS
Sounds like the valve timing is off
Remove the distributor-Put engine no.1 piston on its compression stroke/TDC align camshaft and crankshaft sprocket and at the vibration damper to TDC/0 then install distributor making sure the rotor is pointing to the no.1 cap tower. Fire it up then adjust ignition timing.
May 27, 2009 at 1:26 PM
