1991 Mitsubishi Eclipse cut of switch to ignition
117,000 MILES • 6 CYL • 2WD • MANUAL
RBALLARD
please help: I drove my wifes car to auto part store for fuses. came out to go home, turned ignition key and the car made a clicking sound but nothing after that. please advice?
Thank you!
rballard
Feb 17, 2010 at 2:38 PM
  • 75,988 POSTS
Pick your symptom:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Feb 17, 2010 at 2:48 PM
