my clutch stopped working and smoke came from the hood clutch would not disengage
Feb 21, 2010 at 3:11 PM
✓Experienced Mechanic
Hi there,
Sounds as if you have destroyed the clutch plate, but first do you still have a pedal? that is do you still have pressure on the clutch? if you have lost pedal pressure check for a fluid leak in the hydraulics, otherwise i feel it will be the box out and check for clutch damage.
Mark (mhpautos)
Feb 21, 2010 at 3:55 PM
TYLERMNJOHNSON
MEMBER
ah its my clutch fork
how do i go about fixing that
Feb 21, 2010 at 4:00 PM
The transmission will have to be removed, do you have the equipment to do this job?
