2005 Mitsubishi Diamante engine stall
2005 MITSUBISHI DIAMANTE
93,000 MILES • 6 CYL • FWD • AUTOMATIC
GOLDEN INK
my car stalls sudenly while driving and keep loosing acceleration anless i accelerate more.
my friend says it a sensor problem however when i check the did a computer check it revealed no problem. i red about sensor in the website and it said that some sensors are damaged and they cannot be identified unless by a specialized person.
Oct 30, 2010 at 6:28 PM
KHLOW2008
  • 41,814 POSTS
Hi Golden ink,
If no trouble codes are present, the sensors should be woerking correctly but you would need a scan tool to read the various sensors to check if any are working out of specs.
Have you checked the spark plugs and fuel pressure?
Oct 31, 2010 at 3:56 AM
GOLDEN INK
Hi KHLow2008
thanks for your reply
i have checked the car using computer by revealed no errors.
well i didn't checked the pressure and sparks.
i will check them as soon as possible.
thanks
Oct 31, 2010 at 6:44 PM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Keep me updated of the progress.
Nov 1, 2010 at 3:16 AM
