2002 Mitsubishi Diamante alignment camber kit
11,300 MILES • 6 CYL • FWD • AUTOMATIC
PROTONDO
Hello:
Just had a front end alignment
Car had a slight pull to the right
l
Alignment completed - shop suggested a camber kit for Right front - spec range -0.5 -0.6
camber actual reading -0.7-
caster actual 2.1 spec range 2.5-3.5
Dealer states that they do not produce a camber kit a
Any suggestions on how to get this corrected
Thanking you
pr
Feb 29, 2008 at 6:39 AM
PROTONDO
[quote:845d798504="protondo"]Suspension problem
2002 Mitsubishi Diamante 6 cyl Front Wheel Drive Automatic 113,00 miles
Hello:
l
Thanking you
pr[/quote:845d798504]
Feb 29, 2008 at 7:17 AM
SILLIQUE
  • 7 POSTS
you may be able to install an aftermarket cam bolt that would allow for adjustment. however, .1 degrees camber, out of spec, will not cause excessive tire wear.
Sep 30, 2008 at 8:01 AM
