2002 Mitsubishi Diamante 125000 miles
Left rear tire is rubbing very significantly, starts at very low speeds and keeps going at high speeds. I've had alignment checked and done even though it was said to be fine. New tires, new rear brakes, no change. Forceful braking (ABS is currently not working) causes car to fishtail slightly to left, as does any fairly sharp or high speed right turn.
This is driving me nuts!!!
First symptom I noticed was the fishtail when turning right. Asked mechanic to check it and he couldn't find the cause. Shortly after visiting the mechanic the rubbing started and has continued to get worse. What could it be?
Sep 2, 2009 at 8:29 AM
