2000 Mitsubishi Diamante HEATER CORE
2000 MITSUBISHI DIAMANTE
107,100 MILES • 6 CYL • 4WD • AUTOMATIC
CSCHOOLS
  • 6 POSTS
THE HEATER CORE IS BAD AND WAS LEAKING ANTIFREEZE IN THE CAR, A FRIEND OF MIND UNPLUG THE HOSES AND USED ANOTHER HOSE TO CONNECT THEM, BUT NOW IT SEEMS THAT THE CAR IS OVER HEATING. WHAT SHOULD I DO? ALL FLUIDS HAVE BEEN CHECKED.
Dec 2, 2008 at 4:04 PM
S15JIMMYNUT
  • 7 POSTS
did he plug them or bypass the heater? Their might be an air pocket in it? You need to fix it right.
Dec 2, 2008 at 5:52 PM
CSCHOOLS
  • 6 POSTS
he bypass the heater
Dec 2, 2008 at 6:26 PM
S15JIMMYNUT
  • 7 POSTS
as long as theirs no kink or abstruction then that should work. I would let the car completly cool and remove the radiator cap. check to see if its full. Sounds to me like an air pockett?
Dec 2, 2008 at 6:37 PM
CSCHOOLS
  • 6 POSTS
Thanks I hope this works. Could you tell me where the heater core is located so it can be replaced. I found one at a mitsubishi dealer.
Dec 2, 2008 at 7:02 PM
S15JIMMYNUT
  • 7 POSTS
I work at a Mitsu dealership. Trust me ints not fun!!! You start by removing the steering column, entire dashboard, cross bar, evacuate the refridgerant, remove the hvac box. And its located in the box. its an 8 hour job at the least. If your not use to this kind of work please save urself the missury. I hate doing them its terrible.
Dec 2, 2008 at 7:09 PM
CSCHOOLS
  • 6 POSTS
Thank you very much. I think I'll let the dealer deal with this.
Dec 2, 2008 at 7:21 PM
S15JIMMYNUT
  • 7 POSTS
Its going to cost $1000+ good luck with it
Dec 2, 2008 at 7:31 PM
CSCHOOLS
  • 6 POSTS
I live in Paulsboro, maybe you would like some extra money
Dec 2, 2008 at 8:08 PM
S15JIMMYNUT
  • 7 POSTS
Sorry I live in Dayton Oh and i think your in NJ? Look into an independit shop that will use the mitsubishi heater core.
Note to the wise only use mitsu heater cores
Dec 2, 2008 at 8:13 PM
