1997 Mitsubishi Diamante shifts hard
170,000 MILES • 6 CYL • FWD • AUTOMATIC
CARRIET379
we just bought it when it was cold it didnt do it but as it got warmer it shifted harder even if manually shifted also it felt like it was missing. transmission going out? headlights also get brighter then a little dimmer and blinkers dont work?
Nov 26, 2008 at 3:43 PM
JAMES W.
  • 2,394 POSTS
The best way to pinpoint your trans problem is to connect it to a scan unit. This will reveal any trouble codes in the shifting and help find the cause.
The "flickering" lights are usually caused by a malfunction in the alternator. You can usually check this by hooking a volt meter to the battery terminals. While the engine is running, turn on the lights, blower fan and electric defroster, if you have it, and watch the volt meter. You are looking for "spikes" in the meter reading. If belt is tight and spikes are present, I would replace the alternator.
On your "missing", you might want to do a good tuneup. Hope this helps.
Nov 27, 2008 at 1:33 AM
JAMES W.
  • 2,394 POSTS
You were still on the donor list, so I'd check to see how your car is doing.
Dec 16, 2008 at 7:18 AM
