when you start the car it will run and idle, but as soon as you put in into gear the car dies. why is this?
Feb 7, 2008 at 11:22 AM
JADO351
MEMBER
Sounds like your torque converter is locking up when put into gear, can you get more rpm then an idle when in park? does it also die when you go into reverse also?
Jul 8, 2008 at 11:55 AM
