Engine not starting
1996 MITSUBISHI CHARIOT
168,000 MILES
ZODLAM
I have my Mitsubishi chariot gdi. The engine once overheated and mixed oil and water in the oil sump(whitish milky colour). I sent the cylinder head for machine work and fitter the cyl head with a new head gasket as well. Now when I crank the engine it makes a sound as if it's about to start but it won't. As I crank the engine light goes off
Oct 8, 2013 at 8:30 PM
HMAC300
  • 48,601 POSTS
Does the neigne have compression is sounds like you have the timing belt off one tooth. This guide has the same engine.
https://www.2carpros.com/diagrams/mitsubishi/eclipse/1998
This guide can help as well
Please run down these guides and report back
Cheers
Oct 9, 2013 at 6:19 AM
BOOPERIII
Thanks for this post I had this problem and it was the crankshaft angle sensor was bad I found it by going over the guides. I love this site.
Oct 24, 2018 at 1:16 PM
