1999 Mitsubishi Adventure Display
1999 MITSUBISHI ADVENTURE
248,907 MILES • 4 CYL • 2WD • MANUAL
FDRECOLETO
When i turn the key switch to the ON position (before crunking), the indicators of the heater , battery and oil icons are no longer displayed. But still it would crank (start) the engine when the key is turned full to the ignition (starting the engine). What is happening on the display? Does it mean there was no heater at all?
Thanks
Mar 4, 2009 at 7:25 PM
THESOLUTIONARE
[quote:e03a06723e="fdrecoleto"]Electrical problem
1999 Mitsubishi Adventure 4 cyl Two Wheel Drive Manual 248907 miles
Thanks[/quote:e03a06723e]
Amigo, most probably there's something wrong with your simple electrical on the panel. Check the fuse connected to the light indicators on the panel.
You still need to give it a few seconds key-on-ON before cranking a diesel engine to allow the glowplugs to glow and burn fuel.
Cheers!
May 15, 2009 at 4:31 PM
