engine crank but wont fire, theres no spark on the spark plugs/ignition wire
Jan 15, 2010 at 6:21 AM
✓Experienced Mechanic
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
