1994 Mitsubishi 3000GT MISFIRING
124,000 MILES • 6 CYL • AWD • MANUAL
AUDISYAYA
MY CAR SUDDENLY STARTED RUNNING SLUGGISH HAVING MISFIRES, DIES WHEN I STOP EVEN WITH THE CLUTCH IN. CANNOT GET OVER 3000RPMS THE MORE YOU PRESS THE GAS PEDAL THE WORSE THE CAR RUNS I HAVE HAD THE FUEL PRESSURE REGULATOR REPLACED AND THE FILTER, PUT NEW PLUGS AND WIRES IN..IM LOST PLEASE HELP
Mar 18, 2010 at 12:27 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following-inspect and test all the following listed below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
Mar 18, 2010 at 3:52 PM
